Hey can someone update me on what mods are good to do to the king coat? Are the fluidizing hoppers out yet? anyone make a vid or have a review of it?
Fluidizing hoppers for King Coat + other mods ...
Re: Fluidizing hoppers for King Coat + other mods ...
Try this thread see if it's what you are after.
viewtopic.php?f=5&t=998
[quote="DxC"] Are the fluidizing hoppers out yet?
Here's the latest version of the hoppers. The main tube is 4" x 10", has the fluid disc, ball valve with swivel connector, brass vent with 18" of tubing and if it's for the King gun I'll drill the 7/8" hole in the cap where the adapter screws in if you want. The hopper can be taken completely apart for cleaning or maint. PBTP has the King gun retro kit with the pumps and adapters with the plastic tube for sucking up the powder. They also have these hoppers so everything could come to you in one box to save on shipping costs.
Originally posted by BeeBobOriginally posted by DxCAre the fluidizing hoppers out yet?
I must be overlooking them, where are they listed on their site?
Originally posted by HarleydadOriginally posted by hjeadesSame thing that was wrong with it!!! It puts AC voltage through the ground clamp.
But you never know maybe some one else will see something. The ctrl box plug goes to the wall recepticle (three wire grounded outlet, 12ga wire feed) and the ground clamp goes to the 4ga. wire that attaches to my spraying rack. The 4ga wire attaches to the rack on one end and the other end goes to the ground rod outside. If you want I can post up pics. No worries. Sorry if I seem snappy not your fault sore subject with me. Kind of like when your bike won't start and you know it should.
Originally posted by HarleydadOriginally posted by hjeadesthe ground clamp goes to the 4ga. wire that attaches to my spraying rack.
The other end of the 4ga wire that attaches to your rack goes to the ground rod, correct?
Originally posted by HarleydadO.K. so if I remember correctly, inside the control box there is no ground wire from the power source to the ground terminal on the back of the control box. There's no where else you could get voltage from. Have you tried it without using the wire from the ground on back of the control box to the 4ga. wire?
I guess it doesn't matter much as another gun is on it's way.
does matter to me at all cost I want to make sure I have not missed anything. I haven't heard from Donald yet he said he would call the day he ships it. He wants to use it first to make sure I don't get another bad one.
I really enjoy using my King Coat gun with the retro kit and hopper. I only use it for big jobs now like rims and frames. I have started using my EW pro gun for small jobs where I just need less then a cup. Now that I have the air flow the way I like it with the hopper it is great to use. The best part of it over the cup gun is that I can turn the gun upside down and never changes the powder cloude or getting in those tight area's is so much nicer.
Originally posted by CrimsonI really enjoy using my King Coat gun with the retro kit and hopper. I only use it for big jobs now like rims and frames. I have started using my EW pro gun for small jobs where I just need less then a cup. Now that I have the air flow the way I like it with the hopper it is great to use. The best part of it over the cup gun is that I can turn the gun upside down and never changes the powder cloude or getting in those tight area's is so much nicer.
