Getting away from fancy two tones and big items and going back to basics for a minutes.
I've done a few parts in mirror colors that seem to have either never gained full gloss or lost some gloss from curing. The other issue is that sometimes parts are easily scratched, not something that should be happening with powder coating. If I just run a rag across the part a few hours or even days later just to clean it up, I will get some swirl marks and light surface scratches. I suspect I'm not following the correct curing schedule.
I've heating the oven up to 400F, sticking the part in and checking every couple of minutes to check part temperature depending on size. Most small brackets seem to reach 400F in about 5 minutes, valve covers in about 10 minutes. I then start the timer and cure for 10 minutes or whatever the powder calls for. After 10 minutes I turn the oven off and crack the door while the part sits in the rack. After about 5-10-15 minutes I pull it out.
Am I doing something wrong? The mirrors look great until any sort of intense light like a flash light, headlight, or just really bright sun hits it. Then you can see the small scratches and dull looking almost gray spotted finish.
Any suggestions? Thanks!
