KING COAT GUN PUMP
  • KING COAT GUN PUMP
    HERE IS A PICTURE OF THE PUMP
    Re: KING COAT GUN PUMP
    Is this the pump for or in the retro kit?
      Yes, the part with the black elbow and blue connection is feed/powder air and the straight tube with the blue connection is dosage air…
        Are they in the catalog. I need to order some cyberslov so I can order it at the same time.
        Retro kit that is. By the way are you in the catalog yet?
          It should be on the website to order soon, but you can call and order from me anytime
            What do you mean by dosage air?
              If you can ever be not busy, I could.
                ok now I have 3 qustions.
                1. what keeps th powder from going out the vent in the hopper?
                2. should the 2 air sources for the pump come from the same location and be the same presure?
                3. how should the KING GUN control unit be hooked up to get all the air lines needed? Are there mods needed to be done to the control unit to make the retro kit and hopper work proper?
                  Question Three is one I'd like to know. There are controls in the box for the hopper air lines.
                    More info will be coming on this by the end of the week. I am doing the conversion today and I am documenting all the steps involved The controller looks like it has the capability to operate the pump everything appears to be there.
                      Look forward to seeing your write up. I got my hopper today
                        Cool thanks Autocycle.
                        The hoppers sweet isn't it Crimson.
                          For those who want pictures just go back and find my cup modifications thread.Go to your local Festo dealer or other supplier who deals with metric hardware and buy yourselves two 8 mm t's and 8mm tubing for input air to the top of your guages. From the bottom of the quick connects on the guages you will need 3x 6mm tubing(included with gun) two tubes go to pump and third tube goes to fluidize air in the bottom of the hopper.The above fluidizes the powder when the trigger is pulled.You can disconnect your air sprayer and send it's input air line to the hopper fluidizing guage thus fluiding your powder constantly and only needing one 8mm T. You can buy quick connectors to go through the metal enclosure or just go from the guages with the 6mm tubing through an extra drilled hole for the fluiding air and dosage air(bolt in back)
