Price quote
  • Price quote
    Have a guy needing a quote for a snowmobile deck Powdercoated black.He is in Montana if it helps, the total materials used were about 80 ft of 2x2 square steel tubing and 16 ft of angle iron....
    thanks
    Re: Price quote
    well, a typical chopper frame is about 24 feet of tube,and i get 280-300 for that. if you have 96 ft of tube and angle i would say in my area i would charge between 600-900 depending on what it looks like,masking,plugs,hard to get to areas.
      Re: Price quote
      What exactly is a snowmobile deck? Like a stand or something, or is it a tunnel/frame of sorts? Will it be an assembly, and what dimensions, or are you just coating the plates and the tubing seperately prior to assembly? Maybe a pic would help me visualize exactly what you'd be dealing with.
        Re: Price quote
        i'm thinking the chasis that the engine and body sit on?
          Re: Price quote
          Its a framed deck that sits on top of the bed rails for a pickup truck.Holds to snowmobiles/Atv's on the deck.It will be welded up so i told him to search out someone with a big oven as its 8'x8'x4
            Re: Price quote
            Here Dan this will give you an idea. Also called a sled deck.
            http://www.discountramps.com/pickup-sno ... atform.htm
              Re: Price quote
              Interesting. Thanks for the clarification. Surprisingly, I've never seen one of those around here.
                Re: Price quote
                They're kinda wierd when you see one for the first time. Makes the truck top heavy - bet it handles like crap. You don't see them cause you get plenty of snow and most people can ride where ever they're going.
