Newbie needs help!!!
  • Newbie needs help!!!
    Hi all.. I've had my booth and oven ready for awhile now and have done some jobs but I have a guy that wants his cycle tank done in the Bonded Harley Chrome Wrinkle. Problem is the tank has been Creamed ont the inside and mudded on the outside. Will the cream withstand the heat and can I sand the mud off and use the primer instead? Any advice???
    Re: Newbie needs help!!!
    this is a sore subject for me, I only do new tanks to try to avoid some of those problems but believe they should be painted. sheet metal inherently has warping,imperfections,and variance. primer can only help so much.and i've had issues covering primer with multiple coats.on a tank you may get a good ground in the tunnel area,ground will be extremly important over primer. I have had some great results doing tanks,but its not worth the aggravation in my opinion. others here have come across this and i'm sure they can give you better info,good luck.
      Hey welcome to the forum obie1.
        Welcome to the Forum obie,
        When you say "creamed" on the inside I assume you mean it's been sealed. The sealer will not take the the cure temp and will create a hugh mess. I'd run the other way.
        The mud will also not take cure temps. As far as using a primer, depends how bad of shape the tank is in.
        Thanks for the welcome... The tank was custom built and was "sealed" on the inside already as he wants to strip the paint off and have it redone. Maybe I will stay away from this one, unless there is another way.... Thanks
          I agree that it sounds like one you don't want to mess with. Welcome to the forum by the way.
