For those that have ground rods - what type/guage wire do you have running to it? I have the rod in but haven't gotten around to hooking it up. Is just a bare #8 or so wire good enough?
Ground question
Re: Ground question
#8 would be fine. The ground lead on most non-commercial controllers looks like #10 or smaller. I have #4 on my ground rod but only because I had some laying around.Dan
Re: Ground question
The best ground is copper water pipe coming into the building from the street or rebar encased in concrete (20' or more). A #8 ground wire is sufficient . If your ground rod goes into soft ground easily (by hand) or with little force it prob. wont be very effective.
