KL PRIMER IS NOT STICKING
  • KL PRIMER IS NOT STICKING
    ok i am powder coating a set of cast aluminum sport bike wheels and the KL primer is just building up it is not coating. any tips?
    Re: KL PRIMER IS NOT STICKING
    Make sure you've got a good ground. More info on your prep and maybe a pic would help...
      BeeBob is correct.... grounding is a key factor when coating a part
        Could you explain your statement "KL primer is just building up it is not coating".
        I bet he means it's piling up in ridges or clumps like in corners or something, but not actually evenly covering the part?
