FNG w a question or two
  • FNG w a question or two
    Hello everyone, my name is David I'm pretty much a newbie. I've done lots of small single stage stuff, but decided to try and do a set of wheels that I have had laying around. First I will tell you what I'm working with. I have a 50 kv Caswell cup gun and a 4 x 6 x 4 electric oven. The first thing I did was chemically strip the wheels (which are aluminum, BTW) after which I soda blasted them and pressure washed followed by denatured alcohol. I wanted to do a 2 color scheme with clear over it. So....... I started w/ PBTP mirror black. It went on very nice. I masked off what I needed to and did the "inserts of the wheels in PBTP Bonded silver sparkle. Again it went on great and came out looking good. So then came the problem. I have PBTP super durable high gloss clear to go over all of it. When I coated the wheel w/ the clear (before cure) I thought I had a descent looking coat over it, but after 10 min. at 400 PM temp it looked like fidos behind. It wasn't glossy at all in fact it looked like a really badly orange peeled matt finish, if that makes any sense. So I guess my question is there secret to doing clear correctly ? I think I shot the clear @ 35 KV, but I wasn't sure how "thick" to lay it on and again what went on seemed to look good before it went in the oven. I'm confident in my prep as nothing touched the wheels other than denatured alcohol. I don't want to screw up the other 3 so any help would be appreciated. Thanks, David
    Re: FNG w a question or two
    almost sounds like not enough clear or not long enough cure i hate clears , everytime i do them i hot flock them . works well and you can sorta see what is going on .
      Did you hot flock the clear on? if so what temp?
        I didn't hot flock. Pretty much did the same routine as the black and silver.
          After doing some reading, I'm wondering if I possibly have an over cure problem. When I shot the Mirror black I did a full cure / cool / mask / shoot silver / full cure / cool / shoot clear / full cure / fidos arse. Any thoughts ?
            I have done as many as 7 full cures on a piece and never had any problems.
              yea HD it's on the whole wheel. I shot it a good 15 min after alcohol. I will get a pic up tomorrow. I've been reading about back ionization also. I'm thinking I could have a combo of problems. Hobby gun and inexperience being the primary two.
                OP can be created by too heavy of a coating or too thin....Gloss is affected by overbake or underbaking the part.....my advice for all new coaters is to use the Glass Clear....over your metallics ...
                http://www.powderbuythepound.com/catalo ... vnhj9nk802
                and the SD Clear over standard colors
                  Doesn't sound like he outgassed them. Would that show up late in the game and ruin his day?
