I would like to powdercoat my own evo cylinders and was wondering if I do is an overbore absolutely necessary.The cylinders were previously rebored and have about 6000 miles on them since the rebore.
HD EVO CYLINDERS
Re: HD EVO CYLINDERS
i did a set of evo cylinder on the bike i built at the beginning of this year , and no re bore . they where fine . actually i would venture to say that the "jugs" get more than 350degs if sitting in traffic . thats just a wild guess but a rebore is not nessacery .
the only time i ever heard of a re bore was on an automotive engine when they get filled for racing applications becuase the "cement" can actually make the cylinders distorted .
like i said it worked fine on the motor we put together so you should be ok . here they are below the engine parts , and the bike
Originally posted by GONGCHUANYou should see the temp. on just the oil alone sitting in traffic at bike week in Daytona. I got rid of the fancy-hi priced digital temp. dipstick after I seen those numbers! Scared the crap out of me!
These are from a 1990 fxr with many miles so there wasn't a whole lot of paint left. lol.
Polished by nature look.The lower part of the fins had next to no paint left but the top part was still nice. I blasted these with no.80 aluminum oxide in my cabinet and in less than 2 hours heads and cylinders were clear of all paint. HD went to powdercoat in the late 90's and these are quite a chore to cleanup.I use aircraft stripper to strip them before blasting.
OK so here is finally my feedback from powdercoating the cylinders. The bore did not distort, but the cylinders will have to be rehoned because their is a little rust on the walls from heating and cooling and their is some dried up crap/powder stuck on the cylinder walls even though they were perfectly clean before shooting and all taped up.
