what base for candies and transparents?
  • what base for candies and transparents?
    just want to know what you guys use for your base color for the candies and transparents from PBTP.
    thanks
    Re: what base for candies and transparents?
    I use a chrome or silver explosion.
      Depends on the look you're going for. For a nice deep even color, a basecoat of anything from mirror silver to any of the reflective chrome powders. If you want a metallic, silver stardust or other light silver metallic. Silver explosion will give you a more pronounced metalflake. If you want to make your candies or transparents darker, use a similar solid color as a basecoat, or a darker gray metallic. There are as many possibilities for basecoats as there are topcoats, and the combinations are endless. I know you were probably looking for a simple answer, but there really isn't one. I'm sure others will chime in as well.
        silver explosion really pops in the sunlight.
        the last time i shot it i layed it on a little heavier and it popped a lot
          The Stardust Silver is nice as well and is another product you get alot of bang for you $$$$...
          POLYESTER BONDED METALLIC ... THIS THERMOSETTING POWDER COATING IS BONDED AND EXTRUDED TO PROVIDE MAXIMUM CONSISTENCY AND A SUPERIOR FINISH ~ CURE SCHEDULE 375F/15 MIN. AT P.M.T. ~ GLOSS @ 60 DEGREE - 72-82% ~ SPECIFIC GRAVITY - 1.21 ~ THEORETICAL COVERAGE @ R.F.T. - 159.63 ~ SALT SPRAY RESISTANCE RESULTS - 2000 HOURS + ~ RECOMMENDED FILM THICKNESS 1.8-2.2 MILS ~ ELECTROSTATIC GUN SETTING AT 60-90 KV~*clear coat recommended for extended exterior applications and improved mar resistance.
            I've had pretty good luck with silver explosion...
              I warned you
              Explosion? is this a party for one or two ?
                I warned you
                Well after I'm done laying it down my face looks like I just had a party with more than just two
                  That tells alot about you .....
