outgassing??
  • outgassing??
    lots of little "craters"
    Stainless that was pre treated with Acetone, Hyper Smooth gun.
    Re: outgassing??
    Ill tell you right now, you are not gonna find many fans of acetone here. Ive never used it, but most folks here say its a no-no. Personally, the outgassing I have seen were much larger bubbles than that. I dont know for sure.
      Re: outgassing??
      What would you recommend for final prep right before coating?
        Re: outgassing??
        Harleydad...that very well could possibly be the problem. That was done BEFORE I put an inline filter on my compressor. I am getting ready to do some steel rims, hopefully problem will be solved because I REALLY dont want to have to strip powder off!!
          Re: outgassing??
          I also doubt outgassing problem. This looks very much like condamination.
          Is your gun/fluidhopper clean?
          Check airsupply as suggested.
          Also check your oven. Sometimes the forced air is contaminated with _old_ powder residue.
          Your picture is not clear enough but it looks like gray or black. Some powders are totaly incompatible (urethans-hybrids). The smallest amount will cuase such craters.
          B
            Re: outgassing??
            most of these guys and gals are much smarter than I, but I usually wipe down with alcohol, let dry, and run over the part with a small torch before shooting.
              Re: outgassing??
              another thought are these spots ? or craters ? if they craters are they going in or out?
