Anyone every coat a caliper that wasn't broken down? I want to do mine tomorrow and was wondering if I could get away without rebuilding them.
Caliper coating
Re: Caliper coating
I would worry about the boots and or square cut seal in the caliper. As well as any fluid in the caliper coming out and ruining your day.I think it would be easier to pop it apart and do it. You can reuse the seal and boot if you take your time poping it apart. I have many times just to clean the gunk out with no problems. Anyway just my opinion. Let me know how it goes.
Re: Caliper coating
I agree with hjeades,think about the time lost you might acure if you do not take them apart and find out later that the seals are ruined.400 deg is not uncommon for brakes to get.Also making sure you don't get any of the fluid from the inside
of the caliper all over the place could be a chore.
scott
Re: Caliper coating
I just shot a pair of Brembos fully assembled. No problems whatsoever. It was at the customer's insistance that I not disassemble them. The hi-temp neoprene compound they use in the calipers can easily take the cure heat. Just thoroughly flush all the fluid out with water, pre-bake to dry them out, then cap the fittings, mask, and shoot. Be sure to flush with clean brake fluid before putting them back in service to make sure there is no burned fluid residue or water left in them.
[attachment=0:udnma67k]100_1361 [640x480].jpg[/attachment:udnma67k]Dan
Re: Caliper coating
The red did bleed into them a little, which I should have known would happen because red is bad for that. I should have done a coat of clear on the front, applied the decal, then re-cleared the whole thing. The white wasn't as bright as it should have been, but the customer was very pleased anyway. Said you'd hardly see it behind the wheels anyway. Next time I'll do it correctly.Dan
Re: Caliper coating
I got them from Mike (2003z) the Kaliper King, and yes they hold up to the cure temp just fine. I've coated over vinyl decals many times. You do have to make sure there are NO air bubbles, because it will bubble through the powder during cure if there is any trapped underneath the decal.Dan
Re: Caliper coating
Originally posted by HarleydadOriginally posted by wiseguyzI got them from Mike (2003z) the Kaliper King, and yes they hold up to the cure temp just fine. I've coated over vinyl decals many times. You do have to make sure there are NO air bubbles, because it will bubble through the powder during cure if there is any trapped underneath the decal.
That brochure hasn't showed up yet, but mail does come by stagecoach here, and the weather's been tough on the horsies!Dan
Re: Caliper coating
Originally posted by [SMJuan]Maybe I missed it... but did you shoot a base coat or primer on those calipers? They look pretty smooth, was the surface rough at all?
No issues with the pinhole, other than you might see it if you get sloppy and make it too big or too deep. When it heats up, it smooths out and all you might see is a tiny dot. An air bubble in your clear shows up WAY more.Dan
