Anyone ever built a DIY oven for large pieces, that do not fit in a regular oven?? I am thinking a brick oven, but wonder how to make a door. Also a heat element and how to control the temp.
DIY Oven???
Re: DIY Oven???
Originally posted by tcr1016Anyone ever built a DIY oven for large pieces, that do not fit in a regular oven?? I am thinking a brick oven, but wonder how to make a door. Also a heat element and how to control the temp.
Try
viewtopic.php?f=5&t=973
Re: DIY Oven???
Check out the thread Mike pointed you to. I created that a few months ago as a way to gather information and show progress on my oven build and it has turned into a great source of information thanks to the input from others. I can guarantee you will find just about everything you need in there and with a little bit of imagination and common sense you will be able to build a good oven.
Re: DIY Oven???
Originally posted by [SMJuan]I watched an episode of Muscle Car on SpikeTV the other day where they cured powder coated parts with cookies baking at the same time.They must've lived under power lines as a kid.
Cooking in a powdercoating oven is a no-no, by the way (or so I'm told).Dan
Re: DIY Oven???
Re: DIY Oven???
Originally posted by zx10Originally posted by tcr1016Anyone ever built a DIY oven for large pieces, that do not fit in a regular oven?? I am thinking a brick oven, but wonder how to make a door. Also a heat element and how to control the temp.
Re: DIY Oven???
I built my oven using cement block. Cement blocks do not hold up well to heat, so you have to insulate it. I used a 1" thick fireproof fiberglass insulation. It came in 24x48" pieces and worked well. You have to line it with sheetmetal to keep the fibers from causing problems. This is going to go against everything you have ever heard, but I use propane to heat it. I took an old turkey cooker apart, and hooked it to a thermostat from a propane oven. I also plumbed in an air line from an air compressor, because you have a hard time getting enough air to the venturi. This causes soot to build up on whatever you are coating, making them black. So far I have had no problems. For a door, I used a couple pieces of sheetmetal, bracing them with 7/8" steel hat channel, and the same 1" insulation between the layers of steel.
